Old 02-17-2020, 09:40 AM   #3
aparke4
Are you planning to use the 986 MAF housing with your new plenum? Are you staying stock tb?
Yes keeping stock MAF housing/ cutting right up to stock air box for use with rest of 3 inch piping (there are some aftermarket alum MAF housing kits but i found a lot of mixed reviews on the quality of the alum)... and I have a cayman/ 911 (996) TB that is 74mm i believe that bolts onto the plenum.
I am also installing a oil catch can in the trunk in line with the stock AOS (replacing that as well for prev. main.) as my boxster just crossed 96k (2002 S)
aparke4 is offline   Reply With Quote
