Old 01-23-2020, 09:53 AM   #18
Hasbro
Originally Posted by rastta View Post
I went with the minimum drop - which on mine turned out to be 18mm. Another reason why I went with the Ohlins - and the fact that height and spring pre load are separate adjustments. The 400/457 are fine on the street.
Brian at Ohlins was pretty emphatic that 400/457 would be fine with my build and using 100 and 200tw tires (two sets). It's not quite a street build.
Hasbro is offline   Reply With Quote
