Thread: Towing a boxter
Old 08-17-2019, 01:23 PM   #10
1PorscheBoxster986
A Porsche Guy
1PorscheBoxster986's Avatar
I had to get my Boxster towed. It must be the flat bed towing according to the owner's manual. It clearly says "vehicle must be towed with all four wheels off the ground, otherwise damage to the vehicle may result." You should use the tow hook (towing eye) that it comes with. I towed it from the front after removing the plug. You can tow it from the back as well onto a flatbed as well. You will need to remove your license plate to see it.
1PorscheBoxster986 is offline   Reply With Quote
