Old 08-15-2019, 09:30 AM   #11
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by Brian in Tucson View Post
Do it yourself. Spend the money on the tools, which are a permanent investment. Also, the 3 ton jackstands aren't tall enough. My system, which I've accumulated over years is a pair of Rhino ramps (plastic, don't bend or rust,) a bunch of 1' by 1' by 2 wooden blocks (from new lumber.) And then an air/pneumatic 12 ton bottle jack (need a compressor for this,) and the 6 ton jackstands. I have a pair of the 3 ton ones, but they don't allow enough room to crawl around and work. Nice for doing brake jobs. The air jack really does make lots of work possible and almost pleasant.
Agreed on the jack stands...the 3 tons don't extend enough to give you room for some things. you need 4 of them.
Buy a decent floor jack, you want at least 24" of lift (harbor freight, low profile long reach has been working fine for me and under 200 bucks) lift bars make it even easier to shimmy up each side and get some separation between the floor and the car.
I toss the tires underneath in case something goes wrong, figuring that will save me from most of the squish if the car falls.
