Old 06-21-2019, 04:39 PM   #13
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
Another WAG. So that doesn't look like a scratch to me. It looks like the window tint is wrinkled/failing? And there are some small bubbles on the bottom left end? I think the grinding noise might be a separate issue from a failing regulator?
Cause might be something stuck between the door rubber and the glass? Although raising/lowering the glass would/should make a vertical line, not curved.
Try peeling the tint off first and see what shape the glass is in underneath.
