Thread
SAI question
01-09-2019, 07:41 AM
3
Tailwind
Tailwind's Garage
Boxster Base
So I removed the Alternator and air pump. This helps access wise. I then removed the right intake manifold. I saw that the check valve input (vacuum side) was not connected to anything. (more on that). I removed all of the SAI components and hooked up everything on the bench and vacuum tested with the HF brake bleeder pump. Everything held up. I blew through the shut-off valve and it was closed tight. I applied 12V to the change-over valve with my bench supply and the change-over valve opened with a resounding clunk, and air moved freely. Initially I couldn't find where vacuum line to the check valve was but found it. I think I might have disturbed it when I cleaned the throttle body a month ago, and it slipped off.
Took it out for an errand and no CEL so far
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind
Find More Posts by Tailwind
