Old 06-11-2018, 06:38 AM   #1
Anker
Change the oil, remove the spark plugs, replace the gas and hand crank the engine a couple of turns making sure you do it in the right direction. If that works crank it with the started to get oil into all the right places, then replace the coils and spark plugs and try to start it.
If you want to be really sure check the vacuum lines and the RMS and IMS seals before you do any driving.
1941 Dodge Luxury Liner Coupe
