Old 05-06-2018, 10:57 AM   #2
Lacostas
As already stated, it's condensation. If it smells like coolant, you may have a leak in the heater core. I would drive it and see if it happens again.
Thanks. Well i did drive it couple hours ago. I had the FAN to "Off" all the time and it was fine. Then after i parked the car, shut down engine and was about to leave, "smoke" started to come out from the center vents. Im not sure how it smells, it smells mostly like Moisture or something close. I checked carpets and no leaks anywhere near the center dash.
Lacostas is offline   Reply With Quote
