Old 01-06-2018, 02:41 PM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by Oldcarguy View Post
High today was 0 degrees F and I was bored so I decided to start my AOS replacement this afternoon. Based on various forum research I expected to find allen head bolts, instead they are torx!
Short pause waiting on torx socket set and 1/4 6” extension delivery from Amazon (arrives tues). The oil you see in the pic is penetrating oil I applied. Everything was dry when I opened up the engine compartment. Dust is due to our road before we had the lime crusher and dust control applied.
More to come on my AOS replacement after I finish and test vacuum at the oil cap.
I believe a good 8mm 6-point socket will remove those torx bolts if you get to warm hanging around indoors. Torx fasteners are OEM starting around 2007up
