Old 11-16-2017, 07:14 AM   #2
particlewave
Originally Posted by RobertKing View Post
The FRUNK has nothing to do with the window or door micro switch. There are no electronics controlling the cable release mechanism on that model year. The window however is a microswitch related issue. It could be slack that you could compensate for but a better and more lasting solution would be replacing the regulator in the door. Not the motor but the regulator assembly itself. In either case, that means removing the door panel which is kind of a pain. My 2001 S has the same issue on the passenger side. I'll be replacing the regulator over the winter months.
WRONG.
The release levers on a cable operated mechanical system are locked out when the drivers side door is closed.
