Thread: red clip
Old 08-03-2006, 09:21 AM   #11
pauldee
Yes, I can confirm that holding the microswitch shut with your finger (little finger) while locking the car does turn on the internal infrared system. The trick is that you have to hold the micro switch in, until after the car checks for anything open. If you watch the red LED on the dash top, you'll see that it flashes rapidly for about 10 seconds when you first lock the car, then slows down to about a flash per second. Hold the switch until the flash slows, then the car is armed, and you can walk away. If you want to test the infrared, keep in mind that it doesn't sound the alarm for about 2 or 3 seconds after you break the beam. So, toss a jacket or something on to a seat, then wait for a few seconds - the alarm should then sound.
pauldee is offline   Reply With Quote
