Old 04-17-2017, 12:39 PM   #1
truegearhead
truegearhead's Avatar
Since you seem to have no margin for error I'd suggest you get 2 springs. That way you don't end up last minute having 2 mismatched springs and outta time.
That's the plan, and you're right about zero margin! I've knocked out the list below over the last two weeks and dropped the car off this morning to have a roll cage installed. It's going to be incredible if this all works out.
-new IMS bearing
-New revised IMS cover
-New rear main seal
-New Elephant racing GT3 control arms
-new tie rods
-coilovers installed
-GT3 rear toe arms
-GT3 brake ducts
-new pads
-new belt
-small diameter underdrive pulley
-new sway bar
-new strut mounts
-oil change
-brake fluid flush
-alignment
The good news it's at least on he ground and running, even if it's way to low with its bad spring
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
