Old 01-27-2017, 08:16 AM   #2
JFP in PA
Originally Posted by Ianbadams View Post
If I just leave it as is will that lead to any problems or will the noise just persist? It doesn't sound everytime.
Also the work you described to lube it, is this easy for a non-mechanical diy-er?
If it is the starter Bendix drive, the noise you hear is when it is grinding the teeth on the flywheel. Over time, this will ruin both the starter and the flywheel, and while the starter is relatively cheap, the flywheel costs about a grand, and cost about two grand to get at and change.
