Old 01-17-2017, 03:59 PM   #1
barkinfool
barkinfool's Avatar
The only other comment that might help a newbie is that even if the tank is hazy, you should be able to see fluid / non fluid line when looking at the tank when shining light from the rear trunk. If not, you definitely need to add distilled water asap & follow instructions provided here. Good luck!
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
