Thread: Water pump Job
Old 01-04-2017, 04:39 PM   #2
jeeper31
jeeper31's Avatar
There are some other challenging/expensive issues:
1. Do you need an AirLift to 'burp' the system when you refill it?
2. If you (wisely) decide to fit a low temp T'Stat ,whose will you buy?
And your old w/p - does it have all it's impeller blades intact ?If not, ask here about retrieving the missing pieces.
3. If you need to replace the Serpentine belt, check all the idler/tension pulley bearings for wear/noise
4. check the alternator bearing.
There are many good reasons for all this PM in Search.
The problem seldom mentioned is if the nut behind the tensioner pulley spins when you try to fit the new belt ..................
And if you want to avoid loss of coolant (again) check the coolant reservoir for deterioration
BTW Walmart coolant works just fine !
Good luck with your project !
Good ideas
I have a new belt but i am not sure how old it is. Do these belts dry up if not used?
jeeper31 is offline   Reply With Quote
