Old 11-15-2016, 01:31 PM   #2
Gelbster
While you are in there.....
look carefully for leaks from
1. the base of the oil/water cooler.
2.The p/s filler neck.- there are 2 'O' rings inside the stem of the neck and one on the cap.It is a bayonet- twist fitting .It may be a good idea to add a hose to the overflow nipple. 5.5mm hose.
