Old 05-25-2016, 02:38 PM   #1
JFP in PA
Hello Walshie,
i also have an MT, but i have a workshop manual. This says a new filling with converter is 9.5 litres and the change quantity is only 3.5 litres.
So if you want to chenge the complete AT fluid i would recommend to do it with a special system that is able to change the complete fluid in the system. There are different systems out there. For example a german system made by Tim Eckart that also uses a cleaner to clean the complete system and then flushes it. More infos: Englisch
Regards, Markus
That system, like many others, will not work on the Tip because it connects via the transmission cooler lines, which the Tiptronic lacks (it has an integrated oil to coolant heat exchanger that is part of the transmission, so the are no transmission fluid to cooler lines, only external engine coolant lines).
