Old 03-14-2016, 07:38 PM   #1
steved0x
steved0x's Avatar
And please make shure that the gauges show correct values. Maybe it's a good idea to data record values via obd.
Regards, Markus
That is a good point. I believe the oil temp to be accurate based on comparison with the built-in temp sensor using durametric to compare, but I have no way to check the accuracy of the oil pressure, except that it seems to match the expected values most of the time.
