Old 02-24-2016, 07:39 AM   #2
DMage
DMage's Avatar
Confirmed its the P250, I couldn't find that SIR made a tool for the later style PTFE seal. Research I did pulled back that the original seal mounting depth was 14mm, and the PTFE is 13mm. With this you would be using the tool designed for properly inserting and consistently applying pressure to mount, and if using the later style seal would need to stop 1mm short of full depth.
DMage is offline   Reply With Quote
