Old 04-15-2006, 10:09 AM   #3
blue2000s
Porscheectomy
Originally Posted by Rail26
My car is a daily driver...even in the winter. We do not get snow here...The only point I was trying to make was to keep my tires at 37 psi for the cold temps I had to put more air in and I forgot to take it out as the weather warmed up. Thats it....
Pressure will go up when you heat up the tires from driving. You're only supposed to check and adjust your tire pressure to the factory specs when the car hasn't been used so that the air temperature is the same as ambient.
