Old 04-14-2006, 02:41 PM   #1
blue2000s
Porscheectomy
Originally Posted by Rail26
I had my tires still pumped up from winter and it hit 90 degrees today. My tires were supposed to be at 37psi (Back) and 30psi (front). With the heat and spirited driving, I ended up at 45(back) and 35 (front). Winterizing is important...REMEMBER TO DE-WINTERIZE.
Tire pressures are only supposed to be adjusted when cold, unless you're at the track making dynamic adjustments
