Old 10-03-2014, 03:16 PM   #22
Jake Raby
Engine Surgeon
The IMS Solution also will utilize oil pressure from the engine to operate. To the OP, when you installed the IMS Solution, did you have any cam deviations recur?
There's a reason why I developed the IMS Solution to use oil from the Oil Filter location, and there's a reason why that's covered under the patent.
For over a solid year I carried out studies on this particular aspect of engine operation. The deviations in OP with these engines can vary by 12-18 PSI based on where the readings are taken from. This is the reason why there's two banks of variable valve timing components.
US Patent 8,992,089 &
US Patent 9,416,697
