Old 06-09-2014, 01:21 PM   #1
JFP in PA
Originally Posted by patssle View Post
If you have one of these synchrometers and a 986 Boxster S....could you put it on the oil filler while the car is running and tell me what the flow rate is? Curious for diagnosing my AOS.
Thanks!
Not what you need to diagnose an AOS; the system should be pulling around 5 inches of water vacuum if the AOS is in good shape, if it is over 7-10 inches of water, the AOS is toast. Note that the measurements are in inches of water, not mercury like most vacuum test equipment.
