Old 01-26-2014, 04:36 AM   #20
rfuerst911sc
Originally Posted by Boxtaboy View Post
FWIW, when my water pump went out on my 01 at 60k, it gave me warning by way of a nice leak under the car. I had enough time to drive it to the dealer...about 5 miles away, and all was fine after they replaced it. I personally don't see a need to replace the WP every 4 years or whatever....it gets replaced when it busts.
As I understand it ( I'm no expert ) the failure you describe is NOT the one to be scared of ( leaking ). The failure to be scared of is the vanes on the pump cracking and sending schrapnel into the cooling passages. As I understand it the cooling passages are fairly small so broken pieces of WP vanes can lodge and cause hot spots. Those hot spots cause cracked heads which then gives you the lovely brown soup of oil/coolant mix. In this failure mode you won't get a puddle on the floor............you'll get a expensive repair bill
rfuerst911sc is offline   Reply With Quote
