Old 10-01-2013, 03:00 PM   #1
ohhh my
Left-side misfire? Some might say happens every day in the White House.
Ok, joking aside, there are four primary causes of engine misfires - a loss of spark, an unbalanced air/fuel ratio, a faulty fuel injector or fuel supply, and a loss of compression. Obviously, there are a lot of components to consider. I'd change the plugs and see if you get a repeat.
If you do get a repeat, then look for components that are common to all of the left side cyls: left side intake plenum vacuum leak, left side fuel rail, left side exhaust leak or failed cat, etc.
Thanks for the detailed reply and places to check. I understand and know where to locate all of them, but where would the left side fuel rail be located and how would I check that?
Cyl.#2 is middle passenger side. Firing order is: 1-6-2-4-3-5, so why did 3 cyl in a row misfire? As you remove sparkplugs inspect closely for variances that might give a clue.
Middle passenger side? I thought all the even are on the drive side from front to back 2, 4, 6... but thanks for the firing order, you're right not only was it all on one side, but all in a row 6, 2, 4.. weird.
ohhh my is offline   Reply With Quote
