Old 03-15-2013, 07:50 AM   #2
Johnny Danger
Johnny Danger's Avatar
Originally Posted by Crono0001 View Post
I'm willing to pay up to 4k for a complete set.
So you shouldn't go any wider than stock, huh?
I plan to eventually run PSS9s
A budget of 4k will open up numerous possibilities. Again, there's no reason to stray beyond 8.5 for the front and 10 for the rear. If you plan on adding PSS9's, then I strongly recommend calculating offset more carefully. With PSS9's you'll have to take into consideration that the perch and lock ring will present some challenges with regard to clearance. No worries though - JD's here with the exact specs you'll need. First you need to find a wheel.
