Old 04-16-2012, 03:23 PM   #1
Highlow
Originally Posted by Ghostrider 310 View Post
I've tried them with no luck. They're actually on the car right now.
Originally Posted by Burg Boxster View Post
Squeal is typically caused by pad material or shims.
If you're using OEM pads/rotors/shims, only times I've ever had or heard of others having squeal issues is when the brakes aren't getting enough exercise (to cycle and heat them up) and they develop a glaze. Or improperly bedding them. Try going for a spirited drive and really hitting them hard to heat up.
If using aftermkt pads or rotors... could be any or combination there of and there have been many issues w/ different composites causing issues (and of course many trouble free too). To OP, how did you get warp w/ new pads/rotors as they are really beefy other than a really bad component. Wonder if you might have a caliper issue going on too?
Good luck
It has nothing to do with bedding them or warming them up. Current set is OEM from the dealer.
I have no idea how the 'warp' happened, but it was incredibly annoying also.
My next attempt at a solution will be to grind the leading and trailing edges of the pads down, I've heard that this can be a solution.
Highlow is offline   Reply With Quote
