Old 03-17-2012, 04:08 PM   #1
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by jim_hoyland View Post
Update: Had the car on a lift today and blew compressed air up the drain tubes. Gees, what a bunch of junk, electrical tape, candy wrapper, two leaves, and misc debris.
It's supposed to rain Sat in So Cal, so I'll get to test it out
Be extra careful when using high pressure air to blow out the drain tubes. This tends to blow off the hose from the upper mounting point at times. If this happens all the water that would normally go down the drain will be in your interior.
