Old 09-27-2005, 09:00 AM   #1
Porschev
Excuse me,
Here is more information, and once more sorry for my humble English.
The problem started then in july, left axle separated from flange, bolts were borken off and missing. Garage did the following jobs:
1-left axle flange threads damaged-remove left axle, drill broken bolts and repair/clean threads. Remove all bolts from right axle, apply thread locker adn reistall and tighten.
2-left rear wheel bearing is worn-remove left knuckle and wheel bearing. find hub worn also, repalce wheel bearing and hub, reinstalle knuckle.
1997 manual odometer 55k
Ans this problem happened again. Mechanics theory, the axle have some inclanation so that its not tight there.
Thank you
Alexander
Porschev is offline   Reply With Quote
