Old 12-05-2011, 11:22 AM   #1
gregdacat
gregdacat's Avatar
Once it settles down and starts running "normal" check and see if you can remove the oil fill cap while it is running. If not, or if it is difficult to remove (suction) it is most likely your AOS (Air Oil Separator) Mine had the exact same symptoms just before the AOS went south.
Greg
2002 Triple Black, Desnorkled, Bumper Plugs, LN IMSB Upgrade
gregdacat is offline   Reply With Quote
