Old 10-07-2011, 02:53 PM   #2
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by stephen wilson View Post
Is it worth the effort? The throttle will over-ride the cruise control, and when you hit the brakes it will turn off.
Agreed. Even if it's activated by accident, a touch of the brake pedal turns it off imemdiately. I understand the concern, as it could be a problem on some cars, but I don't think you should be worried about it, and if you notice the light has turned on by you brushing against the switch or something, then you can just shut it off. Seeing as you have to press the switch forward (toward the front of the vehicle) in a very deliberate motion in order to set the cruise speed, it's not likely you'll activate it accidentally.
-O/D
IMSR + RMS
Robbins glass window top
