Old 08-30-2011, 10:03 AM   #1
jaykay
jaykay's Avatar
Originally Posted by The Radium King
i lost my shifting at the end of an hpde one weekend and think it was actually the cable (and lots and lots of heat) that was the issue, not the transmission. the transmission cable crosses an a/c hose (which had partially melted through) overtop of the engine (where the heat hangs out) and down to the transmission where the mechanism is protected by a shield (which is what i think was rattling at the end of the day due to excessive heat soak).
once the car cooled all was fine. so, check the cable where it connects to the transmission and at the top of your engine for heat damage.
This sounds like exactly like my symptoms. I didn't know that the shifter cable ran over the engine and will be sure to check this out. Thanks for the input. I also melted and balled up my ps2s trying to stay with the pace of a 996 4 and turbo. The turbo was in and out of his PSM and could blast into corners much faster after a straight. 993s were on me as well as soon as I made a mistake in a corner...anyway just learning ....will do a post about this soon
986 00S
