Old 05-07-2011, 11:34 AM   #1
thstone
This is the rear speaker kit that I installed. Similar to factory kit and is plug and play with the factory CDR-220 radio. Looks factory quality. You already need to have the hard case rear shelf that installs over the engine cover. Fills out the sound rather than providing rear blasting power.
Installation is fairly straightforward. Ignore the instructions about running the cable down the passenger side door sill and across under the dash to the radio and instead run the cable behind the passenger seat tucked under the engine cover and then tuck it up under the center console. This approach is MUCH easier.
http://cgi.ebay.com/ebaymotors/Porsche-Boxster-Rear-Speaker-Kit-1997-2009-Upgrade-_W0QQcmdZViewItemQQhashZitem33677dc427QQitemZ22077 9627559QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
