Old 03-26-2011, 02:47 PM   #1
Gilles
Do not dump the acid and refill it, that will hasten the death of the unit. Top it off with distilled water...... You may want to also consider having it load tested; that will give you a go/no go rating of its condition.
Thanks JFP,
The equalizing cycle just ended (about 4 1/2 hours), and now the charger shows 'full' and the battery never got hot, but I saw the liquid bubbling very slowly.
The instructions called to remove the plugs which I did however, to keep the dirt out these were covered with a folded 'blue paper towel' and the towel ended impregnated with circled shaped holes with minuscule dark particles on it from the cells.
I will let it cool down before starting the engine, a small report will follow afterwards.
Gilles
Gilles is offline   Reply With Quote
