Old 08-15-2005, 05:44 AM   #12
deliriousga
deliriousga's Avatar
Originally Posted by 99-Boxster-MK
IS there a link to a write up on changing the fuel filter?
Mike
http://www.renntech.org/forums/index.php?act=diy&code=diy_ff
They left an important part out:
After you disconnect the battery, you need to release the pressure in the fuel system before taking the old filter off. The relief valve is in the engine compartment on the passenger side. It looks like a huge tire valve stem cap. There's a valve under the cap you need to press w/ a screwdriver to release the pressure. Put a few paper towels around it to catch the gas that will come out and wear goggles in case it sprays. Put the cap back on right after you do this so you don't forget later.
Also get ready for a bunch of gas to come out when you pull the filter. A bunch of paper towels and goggles will keep you good.
1966 Wife White/Brown Top
