Old 12-08-2010, 06:48 PM   #1
ppbon
ppbon's Avatar
Originally Posted by RandallNeighbour
Yes. It's the same for both sides. Just disconnect the battery's negative terminal before you remove the seat (or more accurately, before you unplug the seat wiring from the harness. Removing the four bolts doesn't throw an airbag warning lamp.
I'm pretty sure the airbag light will come on because the seatbelt buckle is part of the seat and the POSIP computer will be looking for that signal.
You would have to remove the buckle and leave it in the car in order to not get the light.
Also, depending on the model year, some seats include an airbag in the seat's side bolster.
If that's the case it will also throw the code.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
