Old 11-03-2010, 05:27 PM   #4
Lucky
Originally Posted by sasha055
Thanks for all the advise!
I have the SIR Bearing Puller I borrowed it from a coworker, however it doesn't have HUB Puller so I'm going to use generic HUB Puller.
I was asking about HUB because with full SIR set you pull the HUB after the axle is out.. with generic puller I'll have to pull the HUB before I take the axle out since it's the 3 legged one that had a bolt pushing on axle.
Sasha
Actually, the SIR kit can pull the hub. You just use only the small nut on the backside of the hub.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
