Old 08-02-2010, 10:14 AM   #1
BoxsterDuke
Angry Shattered Headlight Box Spanner.
Originally Posted by Jaak
Unit is easy to "pop" out.
5mm Allen key required........Insert 5 mm Allen key into the opening and rotate the key 180 degress to the front of the car. Key starts with the handle facing the rear of the car. The headlight pod will move forward. Rotate the key 90 degrees to the rear.......You only have to move the allen key 90 degrees to the rear when installing the "pod". make sure it is locked in.
I followed your instructions Jaak, but mine seems to be a 5mm "box spanner", not a 5mm allen key, got the whole front light assembly out only to find the shop had sold me a push fit bulb and not the bayonet fitting bulb I need. So put it all back together. Got the correct bulb tonight, went to unlock the assembly with the 5mm box spanner......and the whole box spanner shattered in my hands like it was made of glass, nearly slashed my wrists!!!!
Looks like I need to buy a new tool from somewhere now!
BoxsterDuke is offline   Reply With Quote
