Old 06-17-2010, 08:22 AM   #2
schoir
Originally Posted by unklekraker
@ Maurice - it's the switch by the dashboard.
When you said "microswitch inside the latch assembly", is that on the top of the windshield that's holding the tops when it's close or where you put the red clip?
-Gerry
@Kabel- I agree
Gerrry:
It's one of the two microswitches inside the latch assembly receptacle at the center of the top horizontal part of the windshield frame.
I have a little writeup on those two switches in my other computer. I'll post it a little later when I get to that computer.
If it's the switch on the dashboard, you may just have a loose connection behind that switch. You can pry out the small plastic panel on which the two switches (lock and convertible top) and the lighter receptacle sit and take a look behind it.
Regards, Maurice.
schoir is offline   Reply With Quote
