Old 06-17-2010, 06:24 AM   #1
schoir
Originally Posted by unklekraker
Thank you very much, guys! The e-brake light is lit on the dashboard, both fuse are still good, I will check the rest of what Maurice suggested tomorrow at work coz' after I tap the switch (djomlas-nintendo style..hahahaha) it work :dance:
Again, thanks guys...you guys are awesome
Unkle:
If it works when you tap the switch (I'm assuming you are referring to the microswitch inside the latch assembly), then it's definitely that switch as it has been known to malfunction because of excessive heat in the cabin. When you have a hairline crack, the parts expand and the connection on the parallel strips is broken. Flowing a little solder on there usually fixes it.
Let us know if you are referring to the dashboard switch, as that would be a first!
Regards, Maurice.
schoir is offline   Reply With Quote
