Old 04-30-2010, 08:03 PM   #1
longrange9
Mystery solved. The water coming out from underneath the car was the A/C as I stated before and my mystery leak ended up being a leak in the heater core. I had some water on the passenger side (behind seat) last winter, but I thought it was from the convertible top. Plus I had no noticeable drop in water level in the tank reservoir. Last month it must of gotten worst to the point where drop in water level was noticeable. The reason the water was noticeable behind the passenger seat is because the carpet padding is thinner. Otherwise I would of noticed wetness up front under the dash. Easiest heater core I have every installed! As you guys probably know, you don't have to crawl under the dash. It's under the front hood behind the battery. Thanks for your responses.
longrange9 is offline   Reply With Quote
