Old 04-16-2010, 12:40 AM   #1
Kale
Ignition key difficulty
It's the tumbler assembly.. I just had mine replaced with the exact problem. You can force the key in and it will start so you don't have to have the car towed. Just be sure to manually turn the key back left from the start position so the starter won't grind. Also this problem may disengage the alarm.
Kale is offline   Reply With Quote
