Old 11-08-2009, 09:09 PM   #2
Sboxin
Also, there is a You tube video floating around that shows how to check for trans bearing wear -- basically you drain the trans fluid and stick a little finger inside the hole and feel for grease and shavings on the magnet near the drain hole. I'm just passing on second hand info -- but you might also want to check with "Tholyoak" in Kansas who has put several of these motor swaps in older Boxsters.
FWIW, etc...
Take care,
Sboxin is offline   Reply With Quote
