Old 11-02-2009, 01:11 PM   #1
Bladecutter
Originally Posted by babur
Hey Mike
Thanks for the response. Unfortunately I am not familiar with the term AOS and don't know how to check the intake tubes... I enjoy doing small DIY projects though: oil change, brake pads, etc.
No other known issues though with the car. My question is if it's indeed a cat converter issue, what should I be looking at, which brands, how much (I know it's $$$$$).
Bob
The first thing you should do is to relax, and not worry so much just yet.
Lets not assume the issue is actually a convertor as of yet.
Just because the car through a code, doesn't mean for 100% certainty that the convertor is the cause.
If it was my car, I would first start by switching the O2 sensors from the right side, to the left side, and the ones in the left side then go over to the right side.
After the O2 sensors have switched sides, I would then drive the car normally for a while to see if the CEL comes back on. If the light doesn't come back on, then everything is great.
If the light does come back on, then I would do more investigative work.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
