Old 10-10-2009, 01:06 PM   #1
jjanari
I had something similar and it turned out to be a failing clutch switch. however, since you mention putting it in "park" and "neutral," I assume you have a tip??
otherwise, strange electrical can sometimes be a failing ignition switch. have you ever replaced yours?
are you sure the battery is ok (I know you said it "checked out," but I'm not sure how you tested it).
jjanari is offline   Reply With Quote
