Old 09-09-2009, 06:40 PM   #1
986Shaft
Originally Posted by Jake Raby
Is Mark the tech there? He is one of the best techs we have run across in a long time. Are the particles Ferrous metal? Can you post or send me pics of the particles?
Sorry to thread-jack, but if Jake wants to look at pictures of metal, I'll post some. Here are pictures of the filings from my engine. Asked the mechanic to do a leak down test and check for metal fragments. He took off the oil pan/cover (whatever it's called on the Boxster) and found these. He stopped at that point, told me that some of the filings were aluminum and that the engine needed to be replaced. He said that aluminum filings indicated the bearing had failed so severely that the case was damaged. He didn't do the leak down.
Original diagnosis was IMS failure, but nothing was opened up at that time.
First picture is of filings in the bottom of a coffee mug. 2nd picture - most of the filings jump to a magnet, even those that look like aluminum. 3rd picture is what remains in the mug after the magnet - probably just stuck down.
So I believe I didn't learn anything from this exercise. I already expected that at least some metal would be present - even if an engine can be repaired it requires a thorough flush. Maybe the photos tell you something, Jake?
986Shaft is offline   Reply With Quote
