Old 07-29-2009, 04:20 PM   #3
JFP in PA
Originally Posted by mptoledo
Definately a must, I didn't even know they made them. Next years Oil change should be a breeze!! How tight do you tighten the canister? I couldn't get it as tight as i wanted cause of the oil on it from the leak.
Proper torque spec for the filter is 19 Ft Lb; drain plug is 37 Ft Lb......................
