Old 07-19-2009, 05:13 PM   #1
troyjuly
Thanks lil, I believe it is air as well. They had to do the rad flush twice due to an air trap the first time and I don't think they fully got it the second time but it is alot better. I had the wife listen for the fans at the duct behind the passenger seat as well as on the passenger side front with the ac on and all seems to be functioning properly. Should the drivers side front fan come on with the ac as well? Acording to what I have found out so far, the passenger side only with the ac and the drivers side when engine is at hotter than normal temp. Could you please validate that for me? I will follow your advise to try to get the rest and let you know of any further development however so far it seems to be running fine. The car has not overheated yet but does run hotter during town driving which is probably normal from what I have read about the therostat. I have also found a good link to removing the bumper and cleaning the rads which I will follow up on at a later date.
Thank You.
troyjuly is offline   Reply With Quote
