JPF.
that is true. look on the top drivers side of the motor, There is a oil heat sink. looks like a square compact radiator.
part number 996-107-025-57-OEM
if a fan was placed on this part, it would push more air through the fins and cool the oil more.??.
I am going to check the front, and the t-stat, but as an addon this is simple, and if it would cause lower oil temps, that would save the life of the motor, at least from my understanding.
just drove to lunch, and the car went to 198 and stayed there, so i guess something is not right.
I am checking real time temps via the port under the dash.
Did we ever establish what the "normal" temp should be?
2002 S
