Old 07-20-2008, 08:04 AM   #1
Ike
Thumbs up Lower is Better
Hey Guys,
I put Bilstein PSS9s and M030 sways on my 2003 S and dropped it almost 2". It still has rake from front to back. The handling quality is terrific. The M030s keep it flat as a go-Kart. If a base boxster is a 5, stock boxster S a 7, then the current package is a 9! I have adjusted the Bilstein damping to 3 on the front to dampen rebound, and left the rear at the 5 setting so that I can hook the power up past the apex.
My wife gave me the gears saying that the ride would be too harsh. But she has now been a passenger to a radical 2 lane mountain excursion and thinks that the PSS9s are a better ride than stock. (wheww)
The Boxster can give you extreme levels of performance if you want to put the right stuff on the corners. Don't stop at a set of front springs if you want to throw your bad boy around!
Hasta,
Ike
Ike is offline   Reply With Quote
